06-16-2025 11:03 AM
Hi, I bought these 3 cam back in Australia and now I am thinking about bring them to US and use them in USA, are these compatible or any surprises do we need to know before plan on bringing them? Thank you
06-16-2025 02:07 PM - edited 06-16-2025 02:08 PM
I live in Australia received a Google Nest Hub Max from the US as part of a giveaway and it works perfectly, so I can't see a problem with Google devices going in the opposite direction.
Are the cameras solar powered or do you have to recharge the batteries? Voltage requirements would be my concern. But if its 110V to 240V you should be OK with a travel adaptor.
06-16-2025 02:59 PM
thank you that helps, i need check on the charger that i received in Australia can it work with 110V in the US if not need to buy an adapter
06-19-2025 06:46 PM
Hi sirimp9,
Thanks for posting in the community, and to @SmartHomeH-TAGS for jumping in! I understand you'd like to bring your three Nest Cam outdoor or indoor (battery) units, which were purchased in Australia, to the USA. I'll be glad to help you with the information you need!
I don't recommend using your nest Nest Cam outdoor or indoor (battery) in a different country than where it was purchased.
Please check out our helpful article to learn more about it: Move your camera or doorbell to another room, home, or country
If you have any other questions please don't hesitate to post them on this forum!
Juan
