Automation Script: Restore previously set temperature after turning the thermostat down
CatmanNRobin
Dear all,
I just started playing with the Automation Script Editor and just asked myself if it's possible to restore a previously set temperature set before a door has opened.
Thanks in advance!
2 REPLIES 2
Hollen_ar_mor
What kind of thermostat have you ?
With my Netatmo I did :
ThermostatSetMode => off  to stop the heater.
ThermostatSetMode => heat  and then, the thermostat go back to the schedule.
Thank you for the hint, I have Homematic IP heaters. I'll give it a try
