Automation after checking weather condition from the given location
rakeshvtv01
Hello Everyone,
Is there a way to check the weather for a given location and based on the condition trigger automation?
I am using wipro smart devices connected to google smart home and we have option to check for the weather from wipro app however there is no way we can do the same via google home automation.
marsh224
Currently, it seems that there is no direct way to check the weather for a specific location and trigger automation based on the condition using Google Home automation with Wipro smart devices. While you can check the weather from the Wipro app, integrating weather-based automation with Google Home may require exploring other compatible devices or third-party solutions.
deedesigners
Not Sure, but one possible solution is to use a weather API to fetch the weather information for the desired location. You can then create an automation using a programming language or a home automation platform that supports API integrations.
@recoveryservicedubai
LovelyM
@marsh224, @deedesigners, thank you for trying to help.
@rakeshvtv01, thanks for reaching out. To answer your question, we don't support automation based on the location's weather, but we do appreciate your thoughts about this. Our team is continuously working to add and improve the features in our Google Home and Nest devices, so feel free to share your feature requests with us. Visit this link to learn more about sending feedback.
If you have additional questions or concerns, let us know; otherwise, I'll close the thread after 24 hours.
Kind regards,
Lovely
