10-05-2025 07:18 PM
I have a few outdoor motion sensor lights. We're in a rural location and have about 15 power failures a year. Often when power is restored there is a brief flicker that my lights interpret as the switch being turned off and back on quickly which turns them on with the motion sensor disabled. I've replaced the light switches with smart ones and would like a routine to run a few minutes after power is restored that turns the light off for 10 seconds and back on, which will re-enable the motion sensor mode.
How to I trigger a routine to run when power is restored?
10-09-2025 05:39 PM
Hi hjfraser,
Thanks for posting. I understand you want to create a routine that activates 10 seconds after power is restored to re-enable your motion sensor mode. I appreciate the information provided. Don't worry; I'll be happy to share more details with you. In this case, the best option for your automations is to check the Developer Center for further assistance.
I hope this information helps.
Jenny
