Automation not running
Wildgift
I have a Google Assistant compatible thermostat outside and a Google Assistant compatible thinq LG mini split system. I set up this automation and it won't run the automation automatically. (Device)
When device (front porch temp) = 90°
Google Assistant via my Google hub is supposed to "turn on (Living Room AC)"
The turn off AC automation also isn't working correctly.
Any ideas why? Thanks
2 REPLIES 2
Derickf
Hi @Wildgift,
Thank you for posting in the community. I understand you are having trouble creating a home automation for controlling your LG mini split with your thermostat compatible with Google Assistant. I'm happy to assist.
To confirm if your specific thermostat and LG mini split are compatible with the automation system, I would recommend you consult the following article for more details: Create advanced home automations with the script editor.
I hope this information helps.
Best regards.
Derick.
Wildgift
Thank you for this information. Only thing is I didn't find a starter condition to enter a thermostat temperature as a condition. device.state.TemperatureSetting is the closest but the at: condition only allows time. Any tips? Thanks
