02-19-2025 06:59 AM
When my doorbell cameras see a person, the home display shows that doorbell for a few minutes.
Worked perfectly for years, not working at all now and I can't seem to find out where to even see the "program". I DO see Home Automations, but can't open it to edit of ensure it's even ON. That said there IS an arrow there that says "starting automation" when I click it .. but it doesn't really .. for any of the doorbells.
02-24-2025 08:14 PM
Hi @RC519
Thanks for reaching out to the Community! I understand that you were having some issues with your Nest Doorbell and the automations. I know how frustrating this situation can be, but don't worry! Let me help you with that.
Before we continue, I need to know some information about your issue to provide you with more accurate information:
Once you have this information, please let me know! I would be more than happy to assist you with this!
Debora
02-25-2025 05:24 AM
Thanks ! I have 3 Nest Hello doorbells, one of which is currently removed and the automation for that one is off. The other 2 work fine and I can say okgoogle, show me the back door (or front door) & I see live video on my Google Display. Not sure when it stopped working, just noticed a week or so ago. I have tried initiating the automation manually but no luck. Interestingly, if currently displaying back door (for instance) and I initiate the automation, it does the 3 min time delay and returns to clock which is the later part of the automation. Also, if I initiate the one that is currently removed, my display will respond with "something went wrong" (have since turned off that one). I wish I could attach scree shots of the metadata automation or standard, older Google mini display. Not sure if this can be related but my newer FireStick does not show live video of these doors when I ask Alexa as in the past. We rarely used it for that anyway tho.
02-25-2025 05:26 AM
03-02-2025 08:29 AM
Apparently there isn't any help here, for Automation issues nor is there any from Google Nest Customer Care Team or their Higher Internal Support team.
03-03-2025 08:26 PM
Hi @RC519
Thanks for the information provided! I was checking some information here:
With this link, you can check how to create and edit automations with a script editor. I also recommend that you erase the automation in your script program and redo it, just to check if the device can work that way.
Also, I found some steps for you because I noticed that you have some issues trying to run the automations. So, let me send you some troubleshooting steps for that:
Let me know if those steps work for you! If not, don’t worry, you can let me know, and I will check more steps for you.
Debora
04-10-2025 07:29 PM
We've been having the same issue for a few weeks (maybe into months now). Any automation related to displaying a camera feed simply does not work. (We have indoor and outdoor Nest cams, and a Nest doorbell)
To turn on a live feed, I need to manually go to cameras on the Google Hub and select one to be shown. REALLY frustrating.
04-11-2025 05:27 AM
I changed my automation to make a broadcast "someone's near the back door" which comes on the Nest Mini (not the Nest Hub/Display). It gets to be a bit annoying for wife if I'm out & triggering it frequently but it's something. I also tried a broadcast "show me the back door" which also came on Mini, but Nest Hub obeyed that verbal command and began streaming driveway. So, my point is you are right, it won't obey the written command (in the automation) and it seems Google folks either don't get it or refuse to reinstate this functionality 😞
Sunday
After all of this— now they increased their nest aware subscription cost without any additional benefits. https://www.googlenestcommunity.com/t5/Home-Automation/Automation-to-display-Nest-Camera-feed-on-Nes... It looks like we are not alone and they are many other threads going on the same issue
Tuesday
Thanks for reaching out to the Google Nest Customer Care Team.
Thank you for sharing the details of your script and setup. I can see you’ve put together a thoughtful automation using your three Nest Hub displays and Nest camera, and I understand how valuable this workflow was for your home monitoring.
Based on the automation you've described, the issue is most likely related to changes that were rolled out roughly six months ago across the Google Home ecosystem. Specifically:
Unfortunately, at this time, automated casting of live camera feeds through scripts or routines is no longer supported, even if the devices remain linked and functional through manual voice commands.
I understand this change may be disappointing, especially if the automation was working smoothly before. While this behavior is now expected, I’ll make sure your feedback is noted for our product team, as automation flexibility remains a top request among advanced users.
