Broadlink RM4 Remote Control by Voice Command
Tommi
Hi all. Hope someone can guide me on this.
I have Broadlink RM4 connected to Google Home.
I can say these commands without issues:
TV channel volume down 5 -> Google turns down volume by 5
TV 10 HD channel -> Google press the channel number
So commands like above are functioning and is all good.
What I cannot do at the moment is asking Google to press in sequence like this:
Input button -> Down button -> Down button -> OK button
Basically doing the above will go to the HDMI 1 input. If above is possible, it will be able to executive so many other things.
Could someone please advice on this please. Is this even possible to do with Broadlink and Google? Thank you.
Azarco
Hey Tommi,
Thanks for reaching out.
Was it working before? What app aside from the Google Home app are you using in controlling your Broadlink device? While we would prefer to support all available features, the number of actions that Broadlink devices support using the Google Home is controlled by Broadlink. We recommend that you reach out to Broadlink for additional information.
Alex
Azarco
Alex
Azarco
Hello Tommi,
I haven't heard from you in a while so I'll be locking this thread in 24 hours. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Alex
