07-09-2025 01:03 AM
I created a automation so when my Nest Outdoor camera detects motion it is to turn on the Govee Patio lights (Gover Outdoor Lights). Then when there is No Motion Detected after 1 minute the lights are to turn off. I saved both automation and hit the "play" to start the automation and it never works. Please help!
07-12-2025 02:07 PM
Hi Doxboi,
Thank you for reaching out to the community. I understand you're experiencing trouble running your automation to turn on your Govee Outdoor Lights when your Nest Outdoor Camera detects motion. Also, when there is no motion, the lights should turn off. I know how difficult this may be, but no worries. Let's work together to find a solution.
If you're having trouble with your advanced home automations, please refer to this helpful article on using the Script Editor to check and verify your setups. If you encounter any situations, please submit your feedback directly through the article's channels.
Additionally, here is an important article to see all the recommendations to create advanced home automations with the Script Editor.
Please let me know if you have any further questions.
Byron
