03-16-2023 05:58 PM
Hi there! So I has the google nest cameras(6) and doorbell installed last week. Today our wifi was upgraded, so the name and password changed. We have reset, redone, rebooted and deleted all devices and even tried to set up a new home to get these back up online but nothing has worked. Any suggestions? I was not able to change any of the wireless info within the Google Home App, hence the ADT recommendation to delete and start over. ugh.
03-16-2023 08:10 PM
When the mesh was installed the tech should have made the SSID ( wifi name you'll see when connecting device ) and password identical to what was there previously. The devices would have reconnected.
Do now what you'll want to do is delete devices off your account. Go to the cameras and pull the power wait a few seconds and let them power back on. Try reinstalling them and if that doesn't work you'll need to factory reset the camera by using the power brick and usb cable the camera came with. Wait until the camera boots all the way up. Then hold the button in on the back of camera until you hear the chime. After they allow them to reboot fully then learn the camera in.
Remember: when you are first learning the camera in you'll need to be close to the camera. The camera first connects to your phones Bluetooth. Once your logged into your home wifi. You're safe to walk away to finish learn in process.
03-22-2023 10:33 AM - edited 03-22-2023 10:34 AM
Hello everyone,
@Tee_Rav, thanks for your helpful suggestions.
Thanks for reaching out, @tlc777. Make sure to properly reset your Google Nest Hub before setting it up with your new WiFi name and password. You may also check out this support article for more information on how to reconfigure your other Google Nest devices.
Keep me posted.
Lovely
03-25-2023 10:43 AM
Hi tlc777,
I am checking in to see if you have tried the steps I provided. Let me know if that helps with your problem or not.
Lovely
03-26-2023 10:56 AM
Dan
