Can Nest adjust temps based on my calendar events? Like a haircut appointment?
denil34
"Hey everyone! Quick question—does anyone know if Google Nest can sync with my Google Calendar? I have random events like gym sessions, meetings, and even haircut appointments. It’d be awesome if Nest could start pre-heating or cooling the house before I get back from, say, a haircut . Has anyone tried this setup or found a workaround?"
Top Community Reply:
"Yes! You can set routines with Google Assistant and Nest. I’ve actually set mine to kick on the A/C 15 minutes before I usually get back from my weekly haircut 😂 You’ll need to connect Google Calendar through Assistant routines and pair it with your Nest settings."
Follow-up Comment:
"That’s awesome! Didn’t know I could make my thermostat part of my self-care routine haha. Fresh haircut and a cool home? Yes please. 😎"
luciaaa
Hi, @denil34!
Thanks for reaching out to the community! I understand you're interested in syncing your Nest thermostat with Google Calendar so it starts pre-heating or cooling before you get home from your activities. I'm here to help!
Regarding your question, direct syncing with Google Calendar for this specific function is not currently available. However, there are two similar options you might find helpful, which I've outlined below:
Feel free to reply if you have any questions.
Ana
