Cannot use Nest Thermostat E humidity sensor to trigger an automation
Greenleys
While the Nest Thermostat E has a humidity sensor, and the humidity can be seen in the Google Home app, I cannot get automation to use that as a trigger.
I want to be able to turn on a dehumidifier in my basement when humidity increases to a high level.
I do not have central air; the thermostat only controls baseboard radiators running on a propane furnace. The thermostat has only Red and W1 wires.
DeboraJ
Hi @Greenleys,
Thanks for reaching out to the community! I understand you're looking to set up an automation with your Nest Thermostat E to turn on a dehumidifier when the humidity increases to a high level. Let me share some information with you about this.
Upon checking, the specific automation you're looking for using the Nest Thermostat E humidity sensor to automatically trigger a dehumidifier is not a currently supported feature. While the Nest Learning Thermostat (2nd and 3rd generations) offers humidity control options that can be adjusted via the Google Home app or the Nest app, these automated dehumidifier settings are not available for the Nest Thermostat E. For your model, any dehumidifier operation would need to be controlled manually.
However, that automation sounds like a great idea! We're always looking for ways to improve our services and products by adding new automations and features like this. I encourage you to share this idea using our feedback form.
Please let me know if I can help you with anything else! I'll be happy to assist.
Debora
