08-16-2022 08:35 PM
Hello, I have a few Leviton Fan Speed Controllers in my house and am wondering when support for variable fan speeds will be available in the Google Home app? I would expect it to work similarly to dimmers in the app with the dimmer circle around the on/off button and from the main Home page dragging the slider enabled device button.
08-20-2022 02:47 PM
Hi PiketFence,
Thanks for posting. Could you send me a screenshot of your Google Home app showing the Leviton devices?
Nikki
08-23-2022 06:14 PM
Hi PiketFence,
Princess
08-23-2022 07:55 PM
Hi thanks for responding. Here is a screenshot of the Google Home app.
Master Fan and Living Room fan are Leviton Devices that do not have speed control in the app. You can also see the Master Light and Nook Light there with the ability to dim. I also included a screenshot of the Leviton App showing fan speed.
08-23-2022 11:19 PM - edited 08-23-2022 11:21 PM
Hi PiketFence,
Thanks for the screenshots you sent. I have verified that this is not yet supported on the Home app as it can only function to turn on/off the fan linked to it. However, it's not impossible as this is most likely the same with controlling the lights. In the meantime, we’d like to encourage you to send a feedback about this feature and also for any features that you’re looking forward to using with our Google Nest devices.
Let us know if you have additional questions, otherwise we'll be locking the thread in 24 hours.
Princess
08-24-2022 07:14 AM
Thank you. Adding a copy of the feedback I submitted for some visibility here:
The ability to adjust fan speeds the same way dimmable lights are controlled is a must have feature in Google Home. I have numerous lights and ceiling fans in my home which I control through the Google Home app and assistant. Asking assistant to change a fan speed works, but I don't like always hollering at Google to set a fan speed and would like the ability to change it from the app. Currently if I want to change the fan speed without Google assistant I need to use the manufacturers app which breaks some of the cohesiveness I have in Google Home. I just figure if assistant knows what to do when I ask to change the fan speed the app should be able to perform the task as well. Thanks for your time.
08-24-2022 11:32 AM
Hi PiketFence,
We appreciate your feedback. Feel free to start a new thread if you need assistance with your Google speakers and we'd be glad to assist you further.
Kind regards,
Alex
