12-19-2023 12:46 PM
I have an outdoor  Nest camera which was working with an existing router.  I changed routers and now of course I have to reconnect the WiFi to the camera.
i couldn’t figure out how to change settings and now the camera is deleted. So I have to add the camera.  It has no QR code but I have a setup code and the serial number.  I inserted the setup code but I can’t seem to get a menu to allow me to insert the last four digits of the serial number.  No phone number to call Nest support either.  Frustrating!   Please help me.
12-19-2023 12:55 PM
Google Nest does not make it easy to update Wi-Fi settings on its devices; that's why they recommend, when getting a new router/modem, to set the network name (SSID) and password to the same values used on your old router/modem. Here's their Help topic:
https://support.google.com/googlenest/answer/9223711
I'm not sure what you mean by "the camera is deleted". Google Nest does not delete cameras. If you did not delete the camera yourself, and if you are able to use the same network name and password on your router, you may regain access to your camera.
Otherwise, look at the details of the Help topic.
12-23-2023 02:34 PM
Hello Jrpavlock,
@Jrpavlock, thanks for reaching out here in the Community. To know more about this issue, I’d like to confirm, what is the light status of your Nest Camera? When connecting a Nest Camera to a new router, it will require you to reset it to factory default and make sure it has a blue light pulsing indicating that it's ready to connect.
To learn more about reset, you may visit our public article about "Restart or factory reset Nest camera or doorbell".
05-26-2025 05:06 AM
Can't get a blue light. Just a white one.
05-26-2025 08:41 AM
You could try contacting Support, where you can explain the details of your situation, such as what happened that led to to re-install, whether you have a 1st gen or a 2nd gen camera or doorbell (which affects whether you re-install in the Google Nest app or the Google Home app, and whether you were able to remove your camera or doorbell from the Google Nest app or the Google Home app (as appropriate):
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
05-31-2025 08:15 AM
Thank you for your tips I’ve been going round in circles for the last couple of days so relieved to be able to contact someone who might be able to help. Suggestion was to disconnect the camera for 50 hours at which point it should lose it’s memory and should be able to reconnect, I hope this is a proven fix and not something to end the conversation.
05-26-2025 05:00 AM
I had same problem. App told me to remove the camera from my devices and then reconnect. It would not reconnect to new wifi. Did you ever get a solution?
02-06-2024 06:15 PM
I just changed my WiFi router and struggled to get my Nest cameras reconnected. Here is what I did..
Push the camera rest button until you hear a little tune. Then wait for a new chime tune (short). This tells you the camera is reset. You have to remove your cameras from the Google Home App or the Nest Home app. On the back of the camera look for a 6digit code it is often very difficult to see. Should be near the power cable if you are connected to power, if not, look for the serial number then look below that for the code. Save that or take a photo of it so you never have to go looking for it again. Then add the camera to your home or nest app. It should add just fine. Only by resetting the camera to factory reset, will your app and camera recognize the new WiFi signal when you get to that point. It took me several hours and some interesting language before I figured it out. After the first camera, it took about 10 minutes each to reset each of the others. Good luck!!!
09-18-2025 07:11 AM
I have nest outdoor, and it doesn’t have reset button, i did everything i could, its not connecting to my new router at all, no meter what i do, so frustrating
09-18-2025 07:14 AM
My bad i think i found it
02-06-2024 06:19 PM
Serial number is not required. See my post below. When resetting the camera using the reset button it takes 30-45 seconds holding that button in to do a full reset. Wait until you hear the google tune and then just wait a minute or so until the second tune. After that use your code. Mine never asked for a serial number. The code alone should work. Good luck
02-12-2024 05:51 AM
@Mlleddy, thanks for sharing with the Community your experience in resolving your concern. We’re delighted that you were able to find a solution, despite the initial challenges. If you have any further questions or need assistance, don't hesitate to reach out to us at the Nest Help Center.
@Jrpavlock, how’s it going with your Nest camera? Let us know if you still need any help.
Thanks for the assistance, MplsCustomer and Emerson.
All the best,
Lance
09-10-2024 05:27 AM
I have change my router and lost contact from App with my two Nest smoke detectors. Quite frankly the whole process of reinstalling is a nightmare. I have only just finished the issues with installing the router (dual band) and Nest appears to want me to give different names to the two bands. At this point my technical expertise gives up.
09-13-2024 01:58 PM
Hi MichaelStaples,
Thanks for posting here in the Community. I am sorry to hear that your Nest Protect is not connecting to a new Wi-Fi network. I’d be happy to help you with that. Let’s check it out.
Since you've already tried the basic troubleshooting steps for your Nest App and Nest Protect not connecting to the new network, let's move on to some more advanced solutions. There are some important details you need to check regarding dual band and network configuration:
Checking Network Settings:
Advanced Troubleshooting:
If the above steps don't resolve the issue please keep me posted. You can also try these steps if you Can’t connect Nest Protect to the app or Wi-Fi and to Troubleshoot when Nest Protect disconnects or is offline.
Please keep me informed.
Mario
09-30-2024 04:32 PM
I’m having a similar issue. I have a Nest camera that was connected to my old wifi network. Now I have a new network and can’t add it.
10-03-2024 05:25 PM
Hi there!
Thanks for posting in the community.
I’m sorry for the inconvenience that you’ve been experiencing with your Nest camera. I understand that you recently changed your wifi network and you are having a difficult time trying to connect the camera back to the app and using the new network. No worries, help is here.
Here I have a couple of questions for you:
In the meantime, here are some steps that can help you:
Please check the following articles: Restart or factory reset Nest camera or doorbell and Set up and connect Nest camera for further information.
Tell me how it goes.
Daniel.
12-30-2024 10:40 AM
I'm stuck on this same problem and pray you can help. I am trying to reconnect a google nest cam after wifi change. there is no qr code or 6 digit code on the bottom of my camera. I see writing that says Google nest cam model G3AL9 IP54. Next line says 5V 1.5a 7.5w FCC ID A4RG3AL9. Next line says connect to a class 2 SELV.LPS Source. next line is made in Vietnam. NO Code that is 6 digits anywhere. PLEASE HELP. Am I looking in the wrong place. It's a google outdoor nest cam with lights. It's installed, could the code be up in the housing??? I'm stuck...thank you.!
12-30-2024 11:25 AM
If you have the Google Nest Floodlight Camera, the QR code was on a sticker on the face of the camera, and the installation instructions advised you to save that sticker in your Quick Start Guide. If you don't have that, you can select "Continue without scanning" and enter the 6-character alphanumeric setup code printed on the bottom of your camera, as shown at about 1:20 on the video in the Help topic below. Note that you'll have to unscrew your power cable to see that code.
12-30-2024 04:07 PM
Thank you. I found the code after unscrewing the cable and removing it. What a design flaw that is! Anyway, I go through set up with the code and it tells me it's connecting to my camera, but it never does. I get a "something went wrong message and try again..." I've reset the camera, reset my router, deleted and re-downloaded the google home app, downloaded the google nest app and tried on it - only to get all the way through where it asks for the last 4 of the serial number, but doesn't give me anywhere to input it and no list to choose from. I also downloaded the app on my wife's phone and walked through the entire process only to get the same "something went wrong..." message...... I'm beyond frustrated and 6 hours into this process!! Any other suggestions are appreciated.
12-30-2024 04:30 PM
I don't have any suggestions on what to do in response to a "Something went wrong" message. (That's not a very helpful message.)
You could try contacting Support:
03-26-2025 11:26 AM
I changed my WiFi info and struggling for days to access the area to change that info
03-26-2025 11:32 AM
Hello is there any one to help
03-26-2025 11:35 AM
See this Help topic.
Because of the challenges involved, Google Nest's first recommendation when getting a new router/modem is to set the network name (SSID) and password to the same values used on your old router/modem.
07-04-2025 05:40 PM
I have a new Asus Wi-Fi 7 router RT-BE92U. I cannot get the Nest Camera with floodlight, to connect. I reset the camera... And I am connected to the wifi network and next to the camera, but the Home App cannot find the camera. Maybe the camera just cannot find the wifi... I assume if I take the camera off the magnetic base, and unscrew it, and disconnect the cable, the camera loses power? I might try to relocate the router. But I am suspicious that the issue is with how the Asus Router deals with the 3 bands... Anyway, at a loss.
07-04-2025 06:25 PM
Was your factory reset successful, as described in this Help topic (under "Factory reset", not "Restart"):
https://support.google.com/googlenest/answer/9252162
Also, the camera in the floodlight fixture is actually the battery camera (I don't know why they don't document that), so if you disconnect the power cable, it will be running on battery power, as it was when you first installed it in the Google Home app.
07-04-2025 06:31 PM - edited 07-04-2025 06:32 PM
Thanks, I will try the reset again to be sure. I am also going to turn off the 5 And 6 g radios on the router and see if that helps. Thanks for letting me know I don't need to do this on a ladder!
07-05-2025 07:14 AM
So I took the camera down... Did the factory reset, but the camera would not turn on. So I climbed back up the ladder, connected the power and tried to add the camera again in the Home App... And BINGO... Found the new Wi-Fi network and is working fine now. Maybe the battery was not charging... I am not sure. But the factory reset did the trick. I am sure I broke several safety standards up a ladder, using a phone and setting up the camera. But it works! Thanks!
07-05-2025 07:18 AM
lad to hear that it worked, though I can't explain why your sequence of actions succeeded.
08-14-2025 08:29 PM
I am having the same issue. Switched over to Quantom Fiber, deleted all the devices off the google home and nest app... keep getting the C101 error. Two 2nd Gen Wired Cams and 1 Wired Doorbell.
08-15-2025 07:00 AM
Did you also perform a factory reset after removing them from the Google Nest app or Google Home app?
08-15-2025 11:48 AM
These cameras don’t have the reset button. I have had them unplugged for a week or more and tried again last night to the same issue.
08-15-2025 12:28 PM
Your post says you have "Two 2nd Gen Wired Cams and 1 Wired Doorbells". These all have factory reset buttons, as noted in the factory reset Help topic (the second link above).
Only the 1st gen CAMERAS (not IQ cameras and not doorbells) do NOT have factory reset buttons. If you have 1st gen non-IQ CAMERAS, you can only factory reset them by removing them from the Google Nest app while you still have a connection to them on your old Wi-Fi network.
08-15-2025 02:27 PM
That makes sense… so now what?
08-15-2025 02:38 PM
As best as I can tell, your "Two 2nd Gen Wired Cams and 1 Wired Doorbell" have factory reset buttons, and all three need to be factory reset to clear the old Wi-Fi settings (using the instructions I linked to earlier) and then reinstalled.
Another possibility is for you to set the network name (SSID) and password on your new router/modem to the same values used on your old router/modem. This worked for us when we got a new Xfinity router/modem a couple of years ago, and we didn't have to update any of our cameras, doorbells, or Nest Hubs.
08-15-2025 02:56 PM
So I’m thinking that they are the older ones…
I already deleted from my home app, am I going to be able to reinstall if I change the network name?
what a pain!
08-15-2025 04:44 PM - edited 08-15-2025 04:45 PM
It depends.
If you have the older 1st gen Google Nest Outdoor Cameras or Indoor Cameras (NOT the IQ cameras), you can only remove them from the Google Nest app, unless you had previously "transferred" them from the Google Nest app to the "Public Preview" version of the Google Home app (https://www.googlenestcommunity.com/t5/Blog/Expanded-support-rolling-out-all-Nest-Cams-can-transfer-...).
If you removed your camera from the Google Nest app (or, if "transferred", from the "Public Preview" version of the Google Home app), that SHOULD have also performed a factory reset, but I believe you have to have performed the removal while your cameras were still on your old Wi-Fi network, when the app could still communicate with the cameras.
If you have 1st gen cameras and you performed the removal AFTER you were off of your old Wi-Fi network, then I think the cameras got removed from the app, BUT no factory reset occurred on the cameras, and the situation in the Help topic below may apply, and you may need wait up to 60 days for your Nest Aware video history to expire:
https://support.google.com/googlenest/answer/9249728
As I mentioned earlier, the 1st gen doorbells have a factory reset button.
P.S. It is too bad that changing Wi-Fi settings for Google Nest devices is not easier.
09-24-2025 11:16 AM
Need help reconnecting my camera to a new router.
