Chromecast en mode veille!?
Mommm
Salut gang. Mon Chromecast fonctionne bien en général. Mais quand il est trop longtemps activé.. ont dirais qu'il se met hors ligne. Et ensuite, ça prend 20..30 minutes avant qu'il rallume, et je peux rien faire ?? Ya tu quelque chose à faire avec ça ?? Merci!
sicsacol
Hi @Mommm,
Thanks for posting. I understand your Chromecast turns off after using it for a long time, and it takes 20-30 minutes to turn it back on. I appreciate the detailed information shared. No worries, let's work together to figure out the issue you're experiencing. To better assist you, please confirm:
  • What type of Chromecast do you have? You can find this information in the Chromecast and Google TV Streamer specifications article.
  • What's the status light of your Chromecast when it goes off?
  • When your Chromecast goes off, how warm or hot is the device?
  • Does your Chromecast shut down in other situations, for example, when you use a port hub?
Any additional details you can provide will be helpful.
Jonathan
