07-31-2023 01:04 PM - edited 07-31-2023 01:04 PM
I have the nest learning thermostat and trying to see if anyone knows if this is compatible with my system. I had the cheaper nest thermostat and it said it was not compatible. I just need to know if I need to go to a different brand like ecobee or will this thermostat work? If it will work can someone tell me which wires go where?
07-31-2023 01:07 PM
It seems like you're having some trouble understanding the wiring of your thermostat. Have you looked for answer in the Nest Thermostats section?
https://www.googlenestcommunity.com/t5/Nest-Thermostats/bd-p/Thermostats
08-10-2023 09:13 PM
Hello folks,
Thanks for your help here, @DWB1973.
@David2472, I appreciate that you considered using the Nest Thermostat E you have. It appears that your Heat Pump is compatible with it. Make sure to follow the corresponding wires according to their usage. Here's your guide on how you will install it:
Let me know if you need more help.
08-29-2023 07:28 PM
Hello David2472,
I'm checking back in — how's it going? Still need our help with its compatibility and installation? Please check out these articles that would help you in the future:
