06-19-2025 10:31 AM
My goal is setup an automation that would be triggered at 7 pm every night and stream the camera feed of our nursery crib camera on to two nest hub max.
What works:
- The cameras are made by Ubiquiti and I have him integrated into the google ecosystem using Scrypted.
- I can see the cameras in google home under "cameras".
- I can use voice and ask it to "Show nursery crib". It plays without a problem
What doesn't work:
- I couldn't find a command to start a camera stream within an automation
- I tried create an automation with the command "Show nursery crib" but this fails
- I also noticed that if i say "Play nursery crib on family room display" does not work either
Appreciate your help.
06-19-2025 11:24 PM
"My Bedroom Display" is a Nest Hub Max
06-22-2025 05:42 PM
Hi Kezanian,
Thanks for posting! I understand that you want to create an automation to stream a camera feed to your two Nest Hub Max devices. I appreciate the information you provided. I'd be happy to share more information about this with you.
The best recommendation would be to try using scripted automations. These are helpful for creating advanced household routines. The script editor allows you to program scripted automations with additional starters, conditions, actions, and advanced logic.
You can check the "Write scripted automations with the script editor" and "Create advanced home automations with the script editor" articles for more information
If you have more questions, you can visit the Developer Center.
I hope this helps!
Jenny
