07-29-2022 10:38 AM
I have a kitchen overhead light which can turn on in 3 different luminescents. It has no interface other than turning it on and off, and it cycles through the 3 possibilities. The wall switch is a Kasa fall switch which is a Google Home on/off device. I would like a custom routine that tells the Kasa to ON, OFF, ON, OFF, ON, OFF with a short delay between each. The very GUI oriented Google Home doesn't seem to have a way for me to do this. Am I missing something?
08-02-2022 01:25 PM
Yes, I'm doing that now. Unfortunately the minimum delay seems to be 1 second, which drags this out. It would be great if there was a subsecond delay.
08-02-2022 12:27 PM
Hey kmand,
Thanks for reaching out.
Have you tried adding action then adding a time adjustment so that you can set a delay time? You can choose the time when the routine triggers.
Alex
08-02-2022 01:25 PM
08-02-2022 04:44 PM
Hey kmand,
We appreciate your efforts. We're always looking for ways to improve and we appreciate your feedback. I also suggest that you send feedback using your devices by saying, "Hey Google, send feedback," or by following the steps on this link.
If you still need assistance with your Google Nest devices, feel free to start a new thread in the community and we’ll be happy to help.
Kind regards,
Alex
