Do NEST items work on 5G Networks?
ScurrilousDude
I’m installing a NEST doorbell (battery) and a NEST thermostat.  I am having difficulties getting either item online.  I cannot find anywhere where Google or NEST states that their products can login to a 5G Network to access their WiFi.
David_K
Assuming you mean 5 GHz Wi-Fi and not cellular 5G, you can find that information linked below.
Technical specs for Nest cameras and doorbells - Google Nest Help
Nest thermostat technical specifications - Google Nest Help
For Nest Doorbell (battery), it depends on your region. The US model supports both 2.4 and 5 GHz Wi-Fi whereas the model outside of the US only supports 2.4 GHz Wi-Fi.
Nest Learning Thermostat (3rd gen) or newer supports both 2.4 and 5 GHz Wi-Fi, the older models only support 2.4 GHz Wi-Fi.
For help with troubleshooting, I'll link some useful resources below:
Doorbell: Need help with setup? Troubleshoot common Nest cam… - Google Nest Community
Thermostat: Need help with setup? Troubleshoot common Nest The… - Google Nest Community
