09-01-2022 12:01 PM
I recently installed the Google nest Doorbell. Door bell is working find until I setup the camera in my cell phone. As soon as the camera is turned on, the doorbell starts ringing every 30 seconds(approx). I installed new chime and transformer (16V-24v). Can anyone help me?
09-01-2022 12:31 PM
Google Nest says the most common reason for this is mis-wiring:
https://support.google.com/googlenest/answer/9317675?hl=en
Is your Chime Connector wired as shown in the wiring diagram in this post?
https://www.googlenestcommunity.com/t5/Cameras-and-Doorbells/Wiring-diagram/m-p/24455
09-11-2022 05:58 PM
Thanks for your help here, MplsCustomer.
I'm dropping by to ensure that everything is covered here. If you have other questions and concerns, feel free to let me know.
09-14-2022 07:57 PM
Hi Tony67,
How's it going? Still need our help?
09-22-2022 03:15 PM
Hey Tony67,
Archie
09-27-2022 07:38 PM - edited 09-27-2022 07:39 PM
Hi Tony67,
Don’t give up on us yet. Let’s further check this. The most common cause of constant rings during the installation is a faulty wire setup. A faulty wire setup usually happens with complex chimes that have 3 or more wires. Sometimes, these chimes are also connected to intercoms, gates that open and close, or other devices. Contact a local pro for help with advanced installation.
Thanks for your help, Archie.
09-27-2022 05:29 AM
Thanks, Archie for your reply. The issue still exists. I will close this thread for now.
10-04-2022 08:59 PM
Checking back in — did you get a chance to contact a Nest Pro Technician? If so, how did it go?
10-05-2022 10:25 PM
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you happen to have the same concern feel free to reach us out here or start a new thread.
