Doorbell and Speaker
LWNS
I have a Nest Doorbell (Battery) and a Mini Nest Speaker. Is there a way to hear the doorbell chime inside my home.
9 REPLIES 9
@LWNS
Turn on "Visitor announcements" on your doorbell in the Google Home app:
https://support.google.com/googlenest/answer/7672451
It is on but best is still not working ☹️
@LWNS
Are your Nest Mini and your Doorbell in the same Google Nest "home/structure"?  Is "Do not disturb" turned OFF on your Nest Mini?
Yes they are and no the do not disturb is not turned off.
@LWNS
Then I don't know why it's not working. I think I've seen a few other posts like this about the battery doorbell.
You could try contacting Support using the link and instructions in this post:
EdmondB
Thanks for the information. Have you tried to do a factory reset on your Nest Mini? If not, here is a link on how to factory reset Google Nest or Home speakers or displays.
Let me know if that works.
Edmond
EdmondB
Hello LWNS,
Checking in — did you get a chance to try the steps shared by MplsCustomer? If so, how did it go? Let me know if you need more help.
Edmond
LWNS
It didn’t work
EdmondB
I'm sorry for the trouble this has caused you. Let me help you out. Just a few questions: Are your Nest Doorbell battery and Nest Mini Speaker on the same home structure in the Google Home App? Have you tried to do a factory reset on your Nest Mini? If not, here is a link on how to factory reset Google Nest or Home speakers or displays.
I look forward to your response,
Edmond
