No solution to simple automation
Bryandurand
I’m trying to set up a simple automation but it doesn’t seem possible
if switch is off for longer than 2 hours then trigger a routine
does anyone know how i can to this?
smarthomie
It should be possible like that:
- starters:
  - type: device.state.OnOff
device: example switch - example room
state: On
is: false
for: 120min
