08-21-2025 04:54 PM
Trying to hook up my Nest WiFi Pro points, I’ve already set up the main router which is hooked up to my ISPs modem, when I try and add a new point by adding a device in the google home app I get this error code at the end of the process once it tries to add the point to the mesh: errors resolving googlehomefoyer-pa.googleapis.com:443:[field:hostname lookup error:address lookup failed for googlehomefoyer-pa.googleapis.com.:errorCode: -65568]
08-25-2025 04:38 PM - edited 08-25-2025 04:58 PM
Hi @jrv1,
Thanks for posting on the community page. I understand you're having difficulties adding your Nest Wifi Pro points to your mesh system because you're getting an error code that won't allow you to finish the process. I appreciate the detailed information you shared. No worries, let's work together to figure out why you're getting that error. To help with that, I have a few questions for you:
Any additional details you can provide will be helpful.
Jonathan
08-25-2025 10:17 PM
Me too!
Who wrote these error messages?
