Google assistant alarm problem
xxCheckmatexx
I use my Google home mini speaker for an alarm everyday and a problem arose about a month ago, every time I specify a alarm time it sets and reads back the incorrect time.  For instance I say , "Hey Google, set my alarm for 6:30am"..and the speaker would play back "Got it, your alarm is set for 1200am"?  I repeat the same command a second time and the same result.  Finally after the second time I say "Hey Google, what time is my alarm set for?"  And the playback says "Your alarm is set for 6:30am" (the correct time).  I have tried unplugging and reconnecting the speaker to WiFi but still the same problem, and it's frustrating going through this routine every night.  Any suggestions or help appreciated?  Thanks
salbando
One way to deal with this (until it gets improved) would be to set your alarm by saying, "Hey Google, set an alarm." The assistant will then say, "Ok, when do you want to set it?", then you can say, "6:30 am". Hopefully, it will then report the correct time. I find that sometimes GH works better when broken into separate statements. Setting events on the calendar is the same thing.
