Have grouped lights changed?
camaroz1985
We have many smart lights linked to our house either from Phillips Hue or Lutron Caseta. For instance the living room has 8 lights, 2 table lights, 2 fan lights, 4 recessed lights.  The lights are labeled “Living Room Recessed Light 1”, “Living Room Recessed Light 2”, and so on.  We used to be able to say “Turn on Living Room Recessed Lights” and only those 4 lights would be controlled.  If we said “Turn on Living Room lights” all 8 lights would be controlled.  Recently all 8 lights respond no matter what you say.  Has something changed? Do I need to make separate rooms for each group of lights?
14 REPLIES 14
Juni
Hi camaroz1985,
This is not the experience that we wanted you to have, let me help you out. Which Nest speaker/display do you own? Your suggestion is another workaround. Before you do that, you can try to do a sequential reboot. First, unplug your Nest speakers/ displays for 30 seconds, then do the same thing to your Wi-Fi router to refresh both devices and your Wi-Fi signal.
Let me know how it goes.
Juni
camaroz1985
We have a Nest Hub Max, standard Hub, and a bunch of minis (7 I think).  I tried to reset the Max and the the Wi-Fi and it is still behaving the same.  Do I need to reset all at the same time, or should I go through and restart them one by one?
Juni
Hi camaroz1985,
Thanks for trying that. Sorry that you are still experiencing the issue.  Yes, let's go ahead and unlink and relink the lights, then observe if this will make any difference. Check the steps below on how to do it.
Unlink:
  1. Make sure your mobile device is connected to the same Wi-Fi or linked to the same account as the speaker or display.
  2. Open the Google Home app .
  3. Tap account (your initial or your profile picture).
  4. Verify the Google Account on screen is the one linked to the speaker or display. To switch accounts, tap the down arrow icon and then choose another account or Add another account .
  5. Select Assistant Settings and then Home Control.
  6. Under Linked services, tap the home automation partner and then Unlink account and then Unlink.
Relink:
  1. Make sure the customer's mobile device is connected to the same Wi-Fi or linked to the same account as the speaker or display.
  3. Tap account (the customer’s initial or their profile picture).
  6. Tap the Search box, type the name of the Home Automation partner then link the account.
    Note: If the home automation account is listed under Linked Services, tap “Reconnect account” then follow the on-screen instructions.
Check this link for more information.
Hope this helps.
Juni
Princesss
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions, otherwise we’ll be locking the thread.
Princess
Juni
Juni
camaroz1985
I tried unlinking the Hue connection and reconnecting it. Still seems hit or miss. I can turn on “Table” lights and “Fan” lights independently, but “Recessed” lights turn on all the lights in the room. Also turning off  any light turns them all off.
Princesss
Hi camaroz1985,
We're sorry for the late response. We'd be happy to take a look into this for you. Please fill out this form with all the needed information then let me know once done.
Princess
Princesss
Hi camaroz1985,
Chiming in-- have you had the chance to fill out the form?
Princess
Azarco
Hello there,
It's us again. We don't want to be a nudge but we'd like to check if you still need our help with controlling your lights. If so, please fill out the form above.
Alex
Yes I do.  I have filled out the form.
Azarco
Hey camaroz1985,
I checked our system and we haven't received the form that you submitted. Did you use the same email that with the one you use in the Community?
Alex
I submitted again.
Azarco
Hello camaroz1985,
We received your form — thanks for filling it out. Our team will reach out to you via email to further assist you. Also, please be advised that this thread will be locked after 24 hours.
Alex
Juni
Hello there,
We haven’t heard back from you, so I'll be locking this thread in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Juni
