11-02-2023 09:05 AM
My battery nest doorbell wont show more than 3 hours of recording even after I've paid for a next subscription of £ 6 per month? Do I need to change the settings or reinstall the Nest doorbell.
11-02-2023 09:28 AM
Is your subscription in the same Google Nest "home/structure" as your subscription?
You can check your subscription here; when you click on the subscription, it shows the "home/structure":
https://store.google.com/subscriptions
That should be the same "home/structure" that displays on the initial screen in the Google Home app.
11-02-2023 10:06 AM
Thanks for your reply, I paid for the subscription on my Google account as per my Google search to subscribe to Next Aware 30 days (£6.00) as the free month which came with the doorbell expired. So frustrating. Really hope you can help? Is there a way to link the payment?
@CliffPalmer Is your subscription in the same Google Nest "home/structure" as your subscription? You can check your subscription here; when you click on the subscription, it shows the "home/structure": https://store.google.com/subscriptions That should be the same "home/structure" that displays on the initial screen in the Google Home app.
11-02-2023 12:21 PM
I'm just another Google Nest customer. Did you purchase your Nest Aware subscription using the same Google Account you are using to sign onto the Google Home app? If so, did you check the Google Nest "home/structure" shown on this link (https://store.google.com/subscriptions) when you click on your subscription? Is it the same Google Nest "home/structure" shown on the initial screen in the Google Home app? They should be the same. (The name of your Google Nest "home/structure" is whatever name you chose when setting it up.)
If you can't figure it out, you can try the "Contact us" option under "Nest Aware Premier Care" on the page below to "Get 24/7 access to Nest Aware Experts on the Nest Customer Care team. They’re available to answer questions, help you access features, and manage your subscription."
11-06-2023 02:31 PM
Hello everyone,
@CliffPalmer, thanks for reaching out to the Community. I wanted to check if you still need help with the Nest doorbell. Have you had any chance to contact the support team as suggested by MplsCustomer above? If yes, how was it?
Lance
11-08-2023 07:57 AM
All sorted now thanks Lance L.
11-08-2023 08:16 AM
Hey CliffPalmer,
Chiming in — I'm glad to hear that. Please feel free to let us know if you have any questions or concerns, by creating a new thread, as we'll be willing to assist you from there.
I appreciate the help, @MplsCustomer and Lance.
