Help with location
Kg77
  • When creating a automation based on location the location field does not populate or allow me to enter a location
2 REPLIES 2
tajennifer
Hi Kg77,
Thanks for posting. I'm sorry to hear about the situation that you are experiencing with the location to create an automation. Don't worry; help is here. I need to ask for some information to provide the best assistance:
  • What Google Nest device do you have?
  • When you created the home, did you enter the correct location?
  • What action do you want the automation to take?
Please keep me posted. I'll be waiting for your response.
Jenny
tajennifer
Hi Kg77,
We're sorry for the inconvenience. There was an issue impacting location starters for Personal Routines in the Google Home app for some users. This issue has been fixed. If you're still running into a problem, please try restarting your devices and let us know if it persists.
Jenny
