Home automations stopped working
SRJ
Google automations that were working beautifully all stopped working.  Is the system down?  I have not changed anything.
cifuentesj
Hi @SRJ,
Thanks for reaching out and providing detailed information. I understand that you're encountering some issues with your routines. I'm here to help you find a solution together.
To assist you further, please attempt the following questions:
  • Have you experienced any power outages in your area?
  • Is this a personal or household routine?
  • Do you see an entry in the Home app feed for the routine running?
  • Is the Activate Routine toggle enabled?
  • Did you receive an error message notification or verbal response from the assistant-enabled device on which the action failed?
  • Is your personal result on?
  • Are both your Google Home app and smartphone operating system up-to-date?
  • Can the action be performed with the Google Home app or Assistant voice command?
  • What model of your Google Home device is it?
  • Did you notice another issue when you try to use the voice commands or just with the routines?
In the meantime, you can follow these articles:
Please keep me posted.
Warm regards,
Jeremy.
p1lhas
I'm experiencing the same issue. when i ask the assistant on google mini or google nest hub, it does not work. But if i run the automation directly from the home app, it works.
hartpartyof6
I find that sometimes they work and other times not. I have them working from my ipad and iphone and if the power goes out and comes back on then the timer won’t work and so there fore I am asking google to turn them off
