01-22-2025 03:43 PM
I work from home, and I have the location of my phone shared with Google for presence sensing, My wife also has location access enabled on her phone but by default, it is set to my phone, at random times all the lights will shut off, the TV will shut off, and the house goes into away mode as "Everyone has left the house" but I'm still HOME... I look in the app and it shows in the activity switched to away. any suggestions???
01-23-2025 08:33 PM
This could be a short work around while you wait for a moderator.
If you use the script Editor in home. Otherwise you could navigate through the usual automation interface to attempt some of these same temporary tweaks.
Set a condition that if smart light, plug, tv, (any devices you have on while you're home) is on, your Google home presence state is set to home.
https://developers.home.google.com/automations/schema/reference/standard/starter
home.state.HomePresence
device.state.OccupancySensing
Or you can include time states mixed with times you're usually home and presence states setting to home.
time.schedule
time.between
https://developers.home.google.com/automations/schema/reference/standard/time_between_state
01-25-2025 05:58 PM
Hi @Joey98!
Thank you for posting in the community, and to @mikethegreat26 for the recommendations! I am sorry to hear that your lights and TV turn off and your house is going into Away mode while you're home. I'm happy to help you!
To help me find the best solution, I'll need to ask you a few questions:
Please keep me posted. I'll be waiting for your response.
Geremi
