11-24-2023 10:01 AM
I have Honeywell ZWStat Z-Wave thermostat. When i open the thermostat to replace with Nest Leaning thermostat, i found that K wire is not mentioned anywhere in manual. I need help to figure out which wire will go where.
Honeywell:
RC and R have one wire directly join with each other.
One direct wire for R
One direct wire for O/B
One direct wire for C
One direct wire for K
4 weeks ago
Hi Mpancholi, Did you ever figure out where to insert the Honeywell K wire into the Nest Thermostat? I have the same question and wonder if it can go into the Y port and just lose ability to run the AC fan only?
John
