Learning Thermostat losing charge
Bruiser
Hi
I've lived in my unit about 5 years with a pre-installed Nest Learning Thermostat. I've only had to charge the unit about once a year until about 6 months ago when it started to need charge every 4-6 weeks. I have no wire C installed but do have Rc, Y1, G, W1.
Current device info: Battery 3.792V; Voc 36.4V Vin 34.33V Iin 40mA(i)
I have the latest software (just ran a check).
Any advice?
7 REPLIES 7
Sorry to hear about the trouble. I wanted to follow up and see if I could be of any help. Are you seeing any error codes on your device? There is a chance you may need to install a C wire/ Nest Power Connector. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Bruiser
Hi - No error codes, just that it needs a charge. Once charged it lasts a few weeks, which is a lot less than it used to. WiFi router hasn't moved so I don't think a poor signal is causing the issue (only thing I can think of).
Perhaps the batteries a losing life, like an old cell phone?
There is a chance the batteries may not be holding a charge as well as they used to. You can resolve that issue by installing a C wire/ Nest Power Connector, as this will give constant power to the device.
Bruiser
Thanks Jake.
Running and Installing the C wire is beyond my skills - I'll discuss with an engineer when next service is due.
EmersonB
Hello folks,
@Bruiser thanks for getting back to us. Sounds like a plan. Keep us posted.
I appreciate the help, Jake.
Jhonleanmel
We appreciate your help here, Ebedia.
Bruiser, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
Just one quick final check in here since activity has slowed down. We haven't heard from you in a while so we'll be locking this thread if there is no update after 24 hours. If you have any new questions, updates or just a discussion topic, feel free to start a new thread in the Community.
Mel
