08-26-2023 09:17 AM
Not sure if this is correct forum, but liked choices and none are my issue.
New LiftMaster garage door/ MyQ app linking to Google Home/ Assistant.
User guides have nothing, online search says its easy to do, but cannot locate the features referenced in either app. MyQ support is useless, agent timed out in the chat.
08-29-2023 10:00 AM
Hi Will65,
Thanks for visiting the Google Nest Community. In linking third-party devices to Google Home, the device and the native app should be compatible with Google Assistant. Make sure as well that the third-party device is already connected and working properly on its native app.
To link:
Alex
01-28-2025 07:08 AM
I do not see Liftmaster or MyQ listed as an option when I try to add my liftmaster garage opener in Google Home
03-08-2025 08:28 PM
so then I guess it wont connect to Google Home
12-09-2025 08:40 AM
is this true? can you not connect liftmaster garage door openers through MyQ to google home hub?
01-10-2026 09:04 AM
Yes, I’d also like to link Liftmaster MyQ garage cameras to my Google Home. It does not appear MyQ is available to link as of early 2026
01-12-2026 08:50 AM
Just to update since I posted originally.
Evidently MyQ is no longer compatible with Google Home. I did find a few suggestions out in the wild about linking through 3rd party apps, but nothing I was willing to try.
