09-02-2021 04:28 PM
Hi - looking for a way to either have a motion sensor that activates WIFI lights (GE), or to utilise the sensors in the Nest Smoke Alarms.
I note there is an option in the Home/Away routine to utilise the Nest Smoke Alarms to activate / turn off appliances, but that is where it appears to end.
It would be great to have a routine, after sunset, that triggers a light on using a motion sensor. Anyone know if this is possible?
Similarly, for the Home/Away routine, have the lights turn on at night when you walk in the door using a time mechanism would work. There is no option however, at this stage.
09-18-2021 06:09 PM
Turn light off please google
