My govee led lights
Aarondl
so i got my my google display at christmas and i got my govee led lights at the same time and ever since then it has been a constant back and forth with me and lights and google when i go to link my lights google says they have connected but they don’t show in linked devices so im a bit stuck and don’t know what to do and i’ve tried deleting apps and reinstalling them and logging out and back in so if you have any suggestions please tell me what to do
Balke01
I've been having the exact same issue. It's strange because the lights still appear in my Google Home app but the voice commands don't work. I've tried to remove the pairing but when I try to unlink I get the error "could not reach Govee Home. Please try again" but I'm still able to control the lights through the Govee and Google Home apps.
Absolutely exhausting and making me want to leave Google all together. This has been happening since 5pm here and it literally worked a minute before it didn't. I'm pretty sure the new update messed with it.
Aarondl
my led lights won’t even show but they work perfectly on the govee app but nothing even shows on the google or the google app it’s quite frustrating as i have been trying for months now it doesn’t bother me having to go to different apps but i would like to tell google turn lights on but it just doesn’t work i just don’t know what to do
@Aarondl
1. Are the lights Matter compatible?
If not...
2. Is the light in a Home and Room?
Try Reconnecting Govee app to the Google Home in Settings...Works with Google.
DeboraJ
Hi Folks!
Thanks for reaching out to the community! I'm sorry to hear that you are experiencing connectivity issues between the Google Home app (or Google products like the display) and your Govee LED lights, making them difficult to control within the app. Let me share some information with you.
Before we continue, thanks to @SmartHomeH-TAGS for jumping in! It is really appreciated.
Regarding this inconvenience, and since you've already tried unlinking and relinking the lights from the Google Home app, our best recommendation is to contact Govee support for further assistance.
I hope this information helps.
Debora
Markopolo6
First, ensure that the power adapter and controller are firmly connected. If you're using Wi-Fi control, double-check that your lights are linked to a stable 2.4GHz network. Resetting the lights and re-pairing them in the Govee app can also help fix glitches. For those who want larger-scale setups—like decorating the whole house exterior for the holidays—it may be easier to hire professional Christmas light installers Texas to ensure a clean, safe, and well-coordinated display.
