NO POWER RH WIRE NOT DETECTED
Teelove62
New HVAC Unit installed. Shorty after the thermostat shut down the unit shut down . The message read, NO POWER RH WIRE NOT DETECTED
Andhanni
This sounds like a HVAC question for the company that installed the unit.
I would not be surprised if the cable is loss on the HVAC side if thr thermostat did not change from the old unit.
There are several safety features built into HVAC systems that will remove power from the R wires (this includes Rc and Rh wires)
Check all of the panels on the furnace/air handler and make sure they are fully and correctly installed, these panels have a safety switch.
Check that the filter is installed correctly and its access panel is properly closed. Again, there is a safety switch.
Check the overflow, consider drain and make sure it's not plugged. It has a water level switch to stop it from overflowing.
Check the thermostat cable on each end and make sure that nothing has come lose.
Thanks for the help here, Andhanni and Patrick_Caezza.
Teelove62, hope that helps, but if you're still having trouble with your Nest Thermostat, please provide us a clear picture of the wiring set up on your old and current thermostat. Also, please provide the power reading on your Nest Thermostat.
Jennifer
EmersonB
Hi Teelove62,
I'm dropping by to ensure that everything is covered here. If you have other questions and concerns, feel free to let me know.
@JenniferV appreciate your helpful response.
Princesss
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Nest Thermostat and we'd be glad to assist you further.
Princess
