01-02-2024 04:19 PM
Nest thermostat.
I have to post here due to the cumbersom time consuming search to just find out how to set my temperature and be done with it. No Eco, no help of any kind from thermostat. No save me money features. Just set the temperature regardless of mode.
I cannot turn off this Eco stuff, (Thermostat insists on saving me money but it is not), so this thermostat is getting dangerous and I am frustrated. Even the people that installed it said they turned it off.
Please help me set the super duper thermostat to just do what I set it at regardless of mode. Whether heat or cold or both. Period. It’s do what “it” wants instead of do what “I” want is not what I paid for.
Thank you.
01-06-2024 02:31 PM
Hello Joelpatt,
Thank you for reaching out to us and sharing the steps you've taken to troubleshoot the issue. I'm sorry to hear you're having trouble with your Nest thermostat. I'd be happy to help you check it out.
I have a few questions for you:
The Nest thermostats can learn your daily routine and automatically create a temperature schedule for you. If you prefer to disable learning and have your thermostat follow a fixed temperature schedule, you can turn Auto-Schedule off. That way the schedule won't change unless you make manual changes to it.
1. Turn off Auto-Schedule learning.
When you turn off Auto-Schedule, your existing schedule will remain but your thermostat will stop learning from your future adjustments.
Google Home app
Nest app
On your thermostat
Choose Settings
Nest Sense
Auto-Schedule
Off.
2. Clear the existing schedule.
Before you decide whether to clear your existing schedule, here’s how to see it:
If you want to completely erase your existing schedule, follow the steps below:
Note: If you have a Nest Thermostat E, you can select Basic to clear your existing schedule and replace it with the default Basic Schedule.
If you don’t set up a schedule after clearing it, your thermostat will stay at whatever temperature you set it to until you select a new temperature. This means it’ll work like a traditional, non-programmable thermostat or like “hold” mode on a programmable thermostat.
For more information, you can check this guide on how to disable learning for the temperature schedule.
Let me know how it goes.
All the best,
Lance
