Nest Connect
grTEXpace
Will Nest Connect work with WPA2-PSK Wi-Fi or must it be WPA2-Personal  only?
David_K
WPA2 is a protocol that supports multiple kinds of authentication. WPA2 PSK stands for pre-shared key. This is the most common method for authentication to a WPA2 network. Everything that supports WPA2-Personal will for certain also support WPA2 PSK.
2 REPLIES 2
David_K
David_K ,  Thank-y0u for the info and feed back.
