03-03-2023 12:32 AM
I have just connected my Nest Doorbell and I'm trying to get it to use my Google Hub as a doorbell chime.
However what I'm reading online is that if I'm using the doorbell through the battery function and not wired, it won't allow it.
Why is that? And is there an alternative to getting a chime in the house using the nest doorbell through its battery option?
Thanks in Advance,
David
03-03-2023 09:44 AM
It would make no sense at all for the "Visitor announcements" function (https://support.google.com/googlenest/answer/7672451) to be unavailable on the battery doorbell when running on battery power alone, and there is no Google Nest documentation saying this is the case, and sometimes Google Nest sells the battery doorbell along with a Nest Mini as a package.
In contrast, the "Indoor chime" function is disabled and greyed out when the battery doorbell is NOT wired because when it is NOT wired, it is not connected to an indoor doorbell chime and therefore cannot ring the indoor doorbell chime.
03-05-2023 03:32 AM
The visitor announcements function is on but I still can't get the hub to function as a doorbell with it.
03-05-2023 06:56 AM
Can you access and view the camera on your battery doorbell from your Nest Hub? If not, is your Nest Hub in the same Google Nest "home/structure" as your battery doorbell?
If you CAN access your battery doorbell from your Nest Hub but can NOT get "Visitor announcements" on your Nest Hub, you could try contacting Google Nest Support (https://support.google.com/googlenest/gethelp).
03-05-2023 05:05 PM
@MplsCustomer, thanks for helping.
@DaveLowery, this is not the experience we wanted you to have, let me help you. A few things: were there recent changes made? Have you tried reaching out to phone/chat support through the link above? Are all your devices on the same Wi-Fi network and frequency like 2.4 GHz or 5 GHz?
It would help a lot if you could do a sequential reboot first:
Once done, ensure the Do Not Disturb function is disabled, here’s how:
You can also disable it by giving the voice command “Hey, Google! Turn off Do Not Disturb”.
Let me know how it goes,
Dan
03-08-2023 05:27 PM
Dan
