04-30-2024 11:13 AM
I bought the Nest wired doorbell and Google hub package. I have them set up on the same WIFI network and I told Google to sync my devices while sitting net to the hub. It answered OK and shows the the doorbell and hub next to each other.
When anyone pushes the doorbell button it does not show a notification on the hub. You have to tap on the screen, press "Home Controls" and then select "Live Video" to see who is near the door bell.
I have read through so many blogs/instructions with no help. Some blogs say both devices need to be setup in Google home App (I did that ) AND the Nest app. I was able to add my Nest doorbell to the Nest app but when I try to add the hub to the Nest app is says it needs to be added to Google Home, so back to First base...
@ links to members
Help needed and appreciated
AJS
05-01-2024 09:35 AM
Since your first post said "I was able to add my Nest doorbell to the Nest app", I assumed that you must have the Google Nest Hello Doorbell, because that doorbell can only be installed in the Google Nest app. (We have 3 of them.)
But if you actually installed your Nest doorbell in the Google Home app (along with your Nest Hub), then you must have the 2nd gen Google Nest Doorbell (wired), which CANNOT be installed in the Google Nest app, and does not need to be installed there.
And if that is the case, then you need to turn on "Visitor announcements" for your 2nd gen Google Nest Doorbell in the Google Home app, as noted in the Help link I shared earlier.
04-30-2024 11:39 AM
The Google Nest Hello Doorbell can only be installed in the Google Nest app.
Do you have "Visitor announcements" turned on in your Google Nest Hello Doorbell's settings in the Google Nest app?
https://support.google.com/googlenest/answer/7672451
We get visitor announcements from our Google Nest Hello Doorbells (installed in the Google Nest app) on our Nest Hubs (installed in the Google Home app).
Are your doorbell and your Nest Hub in the same Google Nest "home/structure" in the Google Nest app and the Google Home app, respectively? (My guess is that the are, because you can view your doorbell's live video on your Nest Hub.)
05-01-2024 09:19 AM
I tried to add the doorbell in the Nest app and I get this message(see attached screenshot). Do I need to delete everything and start again?
It looks like from these steps listed in #5 of this section, I need to install in the Nest App first before the Home App? Just afraid if I delete everything out of the Home app and go back into the Nest app to add the doorbell that I am still going to get the same error message.
Still need help,
Tony
05-01-2024 09:35 AM
05-03-2024 03:46 AM
Thanks very much, that worked. Very tricky to find that option...:-)
11-23-2024 12:04 AM
I am having a similar problem.
Nest Doorbell (battery) is installed on the Google Home app, along with my Google Nest Hub. Both are available to view on my mobile and both connected to the same WiFi.
When the doorbell is pressed, or motion detected, I will recia notification on my phone no problem. However, the Google Hub will not receive the notification. I can view the doorbell live on the hub, but it doesn't receive notifications. I've tried most things on forms etc but to no success. Help!!!!
4 weeks ago
I am having the exact same problem. I have tried every step that I've seen. I have to be missing something. If I am not home to get the alert on my phone, no one knows there is someone at the door which defeats the whole purpose of the doorbell. I am exhausted trying to figure this out
