03-31-2024 04:52 PM
Hello, does anyone know a way to trigger the nest Floodlight to turn on when a 2nd nest cam detects motion ? Hopefully within the home app, not via IFTTT.
04-04-2024 01:55 PM
Hey @Lawcro - Have you tried our automation script editor available on home.google.com? This use case should be supported. Check out our help center article for more info about the script editor. You can also try out the "Help me script" feature to generate a script based on the prompt you described in your post. Let me know if you run into any issues!
04-13-2024 04:48 AM
A little bit of work, but got this working as I hoped. Pretty hamdly feature once you figure it out.
