03-18-2025 10:08 AM
Hi
I got a used Nest Wi fi 2nd generation from E bay in the Us and now it is not connecting to my DSL router in Pakistan.
I have connected the cables and wires properly, the google app is updated and i have internet on the router but the google app doe not pick the router properly.
Is it region locked or is the firmware missing something. The device warranty is showing expired in 2021.
03-18-2025 10:13 AM
Your Nest WiFi (2nd Gen) isn’t region-locked, but it may have compatibility issues with your DSL router in Pakistan. Try these fixes:
If it still doesn’t work, your ISP setup may not be fully compatible. Let us know if you need more help!
03-18-2025 08:50 PM
Hi
1. Factory Reset tried but did not work.
2. ISP supports PPPoE. Below is the message they wrote to me
"Dear Customer,
With reference to your complain, this is to update you that you may configure the L3 (PPPoE) mode on your router or firewall or any other L3 device, we only need to shift our ONT to bridge mode and share the PPPoE credentials with you. Kindly verify the PPPoE credentials 1st by dialing it over your laptop and then configure your L3 device accordingly."
What configuration do i need to do on the PPPoE for my router? This is a Huawei HG8247H router from the ISP (DSL) and I have IPTV and VOIP also.
Please also advise how to check and upgrade firmware on the Google Nest Wi Fi routers and points.
03-18-2025 08:54 PM
HI.
Also would i need to switch off the Wi fi on the Huwaei router?
03-19-2025 07:45 AM
Thanks for providing the details! Let's go step by step:
Since your ISP is using bridge mode, you'll need to configure PPPoE on your router. Follow these steps:
Log into the Huawei HG8247H Web Interface
Set Up PPPoE Connection
To check and update your Google Nest Wi-Fi routers and points:
03-21-2025 04:46 PM
Hi @zabarry,
Thanks for reaching out to the Google Nest community. I'm sorry to hear that your Nest WiFi 2nd gen is not connecting to your DSL router in Pakistan. I'm happy to help you right now.
If you buy the Nest WiFi in the United States, it might not be compatible if you move to another country; since wireless regulations vary by country, you might experience compatibility issues if you move your WiFi device to a different country, and Google will be unable to offer support. It's strongly recommended that you purchase Google WiFi from the country where you'll be using it.
Feel free to keep us posted if you have more questions.
Gabriela
