Nest camera system
caps162
I've had Nest cameras in two of my restaurants for about 5 years. All of the sudden all cameras across 2 separate locations stopped working with the exception of the 2 newest cameras that I added 2 or 3 years go. I've tried everything to get them working. I've completely removed them from the app as a last resort and they won't re-install. I've even cancelled my subscription with the idea that I would start completely over. Any help would be appreciated.
@caps162
Except for some change in your environment (Wi-Fi, which app you are using, transferring 1st gen cameras to the "Public Preview" version of the Google Home app, etc.), I don't think there is any obvious cause to making multiple cameras all fail simultaneously.
Perhaps you should consider contacting Support so they can walk through what's happening in your situation:
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
