Nest schedule issue
Samueltimmm
I would like to schedule my best thermostat to turn off but cannot figure out how to Schedule it to go from the air being on to turning off at 1 am
EdwardT
Hi Samueltimmm,
Thanks for reaching out. You could follow the steps below to schedule your fan.
  1. Open the Google Home app Google Home app.
  2. Touch and hold your device's tile.
  3. Tap Settings .
  4. Select Schedules and then Fan.
  5. Switch Run every day on if you want to set the same fan schedule for all days. Set it to off if you want a unique schedule for a particular day.
  6. Choose a start and end time with From and To.
  7. Set how long you’d like to run your fan per hour. You can choose 15, 30, 45 minutes of run time, or select 60 minutes to run your fan for the whole hour.
Your fan will turn on automatically each day for the time and duration you’ve selected. You can always edit or disable your schedule at any time from the fan menu.
Let us know how it goes.
Edward
MelbaDT
Checking back in — how's it going now? Were you able to try Edward's suggestions above?
Melba
EdwardT
Hi Samueltimmm,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
