06-25-2023 02:00 PM
How can I reset nest guard to factory setting? Pressing 2 for several minutes doesn't work - no message.
09-19-2023 10:30 AM
Hi Ssnema,
Thanks for reaching out. I know it's been a while already. I'm sorry for the delay. A factory reset should only be done in rare cases for troubleshooting. After reset, you will need to go through the setup process again if you want to use Nest Secure. If you reset Nest Guard while your Nest Detects are offline, the Nest Detects will appear as offline in the Nest app. If the Nest Detects are online at the time of the reset, they will be removed from your account.
Note: As a security precaution, a factory reset can’t be done if Nest Secure is armed in Home and Guarding or Away and Guarding, speaking a Heads-Up, sounding the alarm or if the battery is critically low.
