Nest thermostat always says offline.
cleandog
I have a nest thermostat and used to be able to control it with iphone. Months ago I lost the ability to control my Nest thermostat using my iphone. Now it always says offline. I have done everything Nest suggests to remedy this problem and nothing I have ever tried works.
Nothing seems to work.
Trust me I have tried it all, many times.
I have internet and wifi connection. I have restarted both.
I have removed and reset thermostat connection.
I have removed app from iphone and reinstalled it.
I can't find a number to call Nest support.
Can someone help me?
i am stumped
thank you,
Joe
Hameed
I have the same issue with a pixel phone.
The thermostats/nest pro works fine and the utility company can put it in rush hour remotely but I can't do much it from my nest app as it shows most of the time as offline. I kept playing and rebooting etc. but it doesn't solve it too.
Any suggestions would be welcome, what can be done?!
