09-23-2023 05:06 PM
09-25-2023 10:35 AM
Not sure...
You can check here : https://store.google.com/intl/en/widget/compatibility/thermostat/
You'll need to contact Google Support...
09-29-2023 11:49 PM
Hello folks,
Thanks for reaching out to the Google Nest Community Forum. I'd be happy to take a look at this.
I appreciate you lending hands here with the compatibility checker, @Hollen_ar_mor.
@Dcooke1, your heat pump system is Nest Learning Thermostat-compatible. Make sure to connect your existing wires to their proper terminals to avoid incorrect wiring configuration and system setup. Here's a photo of a wiring guide for you. Let me know if you need more help.
