10-02-2023 06:22 AM
The lock keeps going offline. The nest connect is around 4 feet from the lock. I've reset it twice, and it still happens. Any idea what I can try?
10-02-2023 11:45 AM
The battery ?
Your wifi signal is good ?
10-02-2023 03:19 PM
Is the router close? Do you use a mesh system? If so, move one of the routers closer
10-04-2023 08:10 PM
Hey everyone,
@quinnlee, thanks for reaching out to the Community. I’m sorry to hear that you’re having issues with the Nest x Yale Lock. Let’s check it out.
The lock itself doesn’t connect directly to the Wi-Fi network. It uses a bridge like a Nest Connect or a Nest Guard to connect to Wi-Fi. Since your lock gets its internet connection from your Nest Connect or Nest Guard, let’s first check if the connecting product is offline.
Nest Connect
Nest Guard
You can find additional steps here on how to troubleshoot the offline Nest × Yale Lock.
Keep me posted.
Lance
10-04-2023 08:34 PM
I have the Nest Connect, and it's connected to my wifi; I confirmed this several times. The Lock has new batteries and still disconnects. I'm starting to belive that my Nest Connect is faulty.
10-04-2023 08:45 PM
Hi all,
@quinnlee, thanks for the follow-up info. Since the steps didn’t work on your end, the best thing to do now is to contact Yale support for further assistance.
Feel free to reach out if you have other questions in the future.
Lance
