ONN google tv treaming device (stick) remote not paring.
AndréSRD
After taking the batteries out of the remote, it became unpared and now won't pair again even after following all the provided instructions to pair it with the ONN TV stick. The led light on the remote never lights up, almost as if it doesn't work any more, except it was doing so just fine before taking the batteries out. This is a fairly new device.
Jeremyg
Hi @AndréSRD,
Thanks for reaching out to the community. I am sorry to hear that your Google TV device is not pairing, but no need to worry; help is here.
I need to know a few things about your Google TV in order to provide you with a better resolution.
  • What kind of Google TV streamer do you have? For your reference, you can check out this article on Meet Chromecast with Google TV.
  • Is the streaming device near the cast device?
  • What steps have you taken to pair the Google TV streaming?
 I'll be waiting for your response; any additional details you can provide will be helpful.
Jeremy.
Thank you for the reply.
There is no cast device, just the streaming device, conected to a none smart tv.
I have linked the device in question in another repli.
I have followed the instructions to pare the remote, which are to press a small button on the stick to actívate de pareing process, followed by pressing two speciffc buttons on the remote for 5 seconds by which time the remote's led light should light up and pare, but this last bit does not happen.
Jeremyg
Hi @AndréSRD!
We appreciate you contacting the community. Since Google does not support this device, your best bet in this situation is to contact the maker of your Onn Google TV streaming device. Kindly notify me if you have any other inquiries. Thank you.
Jeremy.
