Philips Wiz and google automations routines problem
chrisyahya
So i have a wiz connected bulbs, and trying to use google's automation (routines).
I'm able to turn on lights, turn off lights BUT unable to change brightness, and colors. When i try to set it to for example 70%, once i execute the routine, the lights will turn on, gets bright (70%) and then less a second the light will go dim (12%).
colors too. The google assistant would respond "actually this device doesn’t support this functionality" when i try to change colors. but i could change it manually just fine in light control in google home app.
i dont know it happens.. it's been behaving like this since 2023.
tried to reconnect by using works with google setup, still same.
Muddi
Hello chrisyahya,
Thanks for sharing details about the issue here. I know how challenging it is when you're having issues controlling your light's brightness via voice command. A few questions: what type of Google Home/Nest device do you have? Do you have a scene set up on the Philips Hue app for your Wiz lights? Does the same thing happen when you change the brightness of the light using the native app? Also, have you tried checking with Philips Hue support if your Wiz lights support voice commands to change the light color?
Since you've done reconnecting your Philips Hue account from the Google Home app, I suggest that you proceed with resetting your Google Home/Nest device and see if your device will have the same behavior.
Muddi
4042878140
Rich is a very expensive
4042878140
Eurufub
