08-11-2025 06:56 PM
I'm trying to create an automation that locks my Philips smart lock on my front door at 11pm every night. It will not lock. I can voice command it with Assistant and give it the PIN number, and it will work fine. But not an automation. Any ideas?
08-14-2025 06:15 PM
HI @merrittjr,
Thanks for posting in the community. I understand you're having difficulties creating an automation for your Philips smart lock to lock your front door every night at a specific time. I appreciate the detailed information you've shared. No worries, I'd be more than glad to assist you.
Automations have specific capabilities, and sometimes certain actions, particularly those related to security, like locking a door, require a PIN for security reasons. While the Assistant can prompt for a PIN, an automation cannot. I recommend checking out these articles for more information on creating automations in the Google Home app:
I hope this information helps.
Jonathan
03-17-2026 10:25 PM
I can't get my Philips smart deadbolt to work with Google Asistant. The only thing it will do is open the Google Home app when I tell it to lock or unlock the door and it gives me a option to hold in on the control to perform the task myself. It then asks for a pin but never asks me over voice for a pin.
