10-20-2025 02:39 PM
I have a Gen 2 Ring doorbell with a solid yellow light. I've connected, disconnected, reset and factory reset the unit. Bought it new but gave up after spending WAY to much time working with it. I'm now reopening this wound and need help? Please advise.
10-20-2025 06:45 PM
That's strange, since a solid yellow status light is supposed to mean a factory reset has begun:
https://support.google.com/googlenest/answer/9268073
Perhaps you should contact Support.
To contact Support:
3. Select your device from the dropdown, click "Other", then click "Next step".
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
